Failed startup after putting to sleep.
I have a Late 2011 Unibody MacBook pro which is no longer functioning after having put to sleep. When turning on the fans come on for around a second with the Sleep indicator blinking once and that's it. It goes in this loop if I plug in the charger, I tried all basic troubleshooting:
- SMC resets
- NVRAM reset
- With and without the battery during boot up
I suspect it's the logic board that's causing problems since I almost have replaced all other components recently. Apple outright refuses to repair the logic board, can anyone please help me understand the problem and the resources I would need to fix it?
Thanks much !
P.S - There was a similar thread on the forum but the only resolution was to bring in the logic board for repair. Sadly, I don't have that option here in my city in Germany.
Are you able to even get it into recovery mode or even Target Disk Mode?
Reference: Mac startup key combinations
by Dan
No it wouldn't boot up at all, the GPU doesn't initialise.
by Peter.binary
