Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
display problem. LCD damage?
Hi, I have a problem with my iphone 6. I tried to change battery, but when I reassembled it, probably I reversed the screws, so display seemed to work fine but then showed vertcial lines and turned off. So, it works intermittently, at the minimal contact with the phone display shows vertical lines and turns off, to turn it on again I have to press power button. It's LCD?
Thanks
Add a comment
1 Answer
Chosen Solution
Hey it can be lcd damage, is it the upper left one you placed wrong?(screen connectors) And if so, where did you place it?
There is two long ones, one upper right one, very long. Left upper one a bit longer then the other 3 (center and lower two)
If screws wasn't placed wrong I would check the connectors on the flex cables so they are straight and sets down good in the motherboard. Also check so there isent any dirt in the connectors on the board
2 Comments:
Yes, it's one of the upper right screws. Probably I reversed one of them reassembling the phone. Did I damage motherboard?
by
My mobile model is iPhone 6 same issue in my mobile need help
by
Add a comment
Add your answer
Fabrizio Ruggieri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 646
