SSD drive rebooting, reinstall OS X
Hello,
I m a bit new here,
My question: I having problems install reinstalling OS-X
It worked fine till I restarted my laptop. The now I'm getting the question mark yea!
When I open utilities and want to reinstall Mavericks OS-X. Than it's asking to select the drive for install, but there is no longer a drive to see. When I open Disk Utilities, there is the BASE System OS-X, but I don't see the SSD drive.
So if I try to reinstall OS-X using a flash USB, it stops have way, giving a stop sign.
How do i solve this? Suppose I have to reformat the drive, how do it manage this?
The SSD should work fine, it did , but now it's no longer in the list.
Any answer for this problem is welcome! Thanks
3 Comments
Do you have access ta a Windows PC?
by
Please tell us your exact machine.
by
macbook pro 17 inch
by
Add a comment
1 Answer
Most Helpful Answer
If you cannot see the drive then you cannot format the drive. You should run diagnostics by holding down d during startup. Most likely you have a failed ssd and it will most likely need to be replaced.
Score 1
Add a comment
Add your answer
Jan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 163
