Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
issues after battery replacement
I've had iphone for 2 years and replaced the battery. Everything worked except camera when i put together so reopened and checked connection on back side of logic board. The phone doesn't turn on now. If I plug into wall charger the apple logo comes up for a few seconds and disappears. If i plug into itunes i can get it into dfu mode but cannot restore (get error 1601). The whole time it's plugged into itunes the screen is off. I've disassembled and reassembled several times rechecking all the ribbon connections. I've been very careful not to damage any of the ribbons or connectors. Any suggestions would be appreciated. Do the symptoms point toward any particular component if damage is the cause?
4 Comments
not sure if it matters but the phone is on o.s. 4.1 and is jailbroken
by
what happens when you reinstall original battery?
by
Same thing, screen stays off except for apple logo for a few seconds after plugging it in
by
is it recognised in itunes-any error codes? have you got a serial no. on the battery as there have been lots of issues like this with battery changes and iphones not recognising them.
by
Add a comment
1 Answer
Chosen Solution
As pollytintop said, there have been lots of reports of problems after replacing batteries and upgrading the phone to 4.x. (particularly with the 3GS - What is the battery part number(s) that works with iOS4?)
Do you still have the old battery? You should see a number like APN:636-0366. I've seen some stores saying 3 different serial numbers as compatible.
I'll see if I can find that link which specified numbers, and you can check your new one for a part #.
Found it.
http://www.directfix.com/mm5/merchant.mv...
I don't know if ifixit has done testing on the best 3g replacement like they did for the 3gs. This is worth a read as well:
Replacement battery, of same part number reboots my phone?
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,041
