Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
iPhone 6: Service Issues
I bought an iPhone 6 a couple weeks ago knowing what I was gonna get myself into. It had a muffled speaker and earpiece, a damaged housing (slightly bent), and a service issue. I bought all the parts needed to fix the iPhone and took apart my phone and fixed it. The one thing that is needing to be constantly fixed is the service issue.
I first bought a new antenna shown here. I replaced that "fixed" the antenna issue. The second thing I thought was a problem was the dock connector, so I bought another dock connector. Again, it "fixed" the issue. And so again, I knew the housing might of been the issue cause it was bent at the bottom. So I bought another housing.
The whole time, when replacing these parts, I've had it go from Searching constantly to No Service. Before I replaced the housing, I've had to bend the case back and forth and smack my phone to fix it. Along with resetting network settings and restarting the phone multiple times. This normally took 5-10 minutes.
After replacing the housing, every time I stopped using my phone or switched to wifi for a long time, the service doesn't cut out, but it goes to 1x or nothing. After thinking a restart would do something, it would go to Searching constantly after restarting. After taking out the SIM and putting it back in, it goes to searching to no service. The only thing that really helps is if I turn off my iPhone, open it up and take out the SIM. The only times that I get service back is if I'm using wifi for a couple minutes or I switch airplane mode on and off, that's when I get service back but again, it only goes back to 1x.
Is there anything I could do to test to see what could possibly be wrong or something? I really hate bring a tool kit for my phone everywhere I go. It'd be really appreciate it if I got an answer.
Add a comment
1 Answer
Chosen Solution
Board issue, some chips are knocked loose, causing reliability issues.
Based on the sunken cost you’ve poured onto this thing, the upcoming board level repair cost and the price of a good iPhone 6, this thing is not worth repairing.
Score 2
2 Comments:
Yep, I agree this is pretty much it.
by
I went to poke at the LTE chip on the logic board and It did something when i went to bend the protection cover down. I'm getting LTE again? I don't know, I'll look into upgrading anyway. Thanks for the help, it wasn't what I wanted to hear but at least I know what is stressing me out lol
by
Add a comment
Add your answer
Ryosuke Johnson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 352
