1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Toshiba 80 GB HD failed while running Bootcamp in PC mode.
My Mac mini had itsToshiba 80 GB HD fail while running Bootcamp in PC mode. When I try to format a replacement HD the Mini refuses to start up in Macintosh mode and is expecting a PC formatted drive. I get a PC command line style "No Bootable Drive Found-Push Any Key To Restart" error.
When I try to push the "C" key to select a proper start up drive so I can restart with the OS X install DVD the Mini which is still in PC mode fails to respond to my Aluminum keyboard since Bootcamp has not loaded and the PC part doesn't recognize a Mac keyboard.
Is there any way out of this so I can switch back to Macintosh mode and finish replacing the HD?
Add a comment
1 Answer
Chosen Solution
Zap the PRAM by starting up holding down the Option - Command - P - R keys. Hold for three tones then restart holding down the "C" key with the system installation disk in.
Score 2
Add a comment
Add your answer
cmfic1 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 575
