Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
replaced the HDD with an SSD and broke the fan
So my Mac Mini Mid 2011 has no temp sensor for the HD. I recently replaced the HDD with an SSD and in the process broke the fan...so I got the replacement (a 610-0069) and as soon as I press the power button the fan comes on full blast. I even tried to use fan control applications which sees the speed its running at but can't turn it down. Any ideas?
Add a comment
1 Answer
Most Helpful Answer
I would recommend you install an app that allows you to see more fully the status of the different sensors in your system. Install: TG Pro. Do make sure you've removed your other temp control app so TG Pro is not confused. Take a screenshot of the main window so we can see the different sensors and paste it here for us to see as well.
Score 2
1 Comment:
@danj more of an answer than a comment.
by
Add a comment
Add your answer
Joseph Cummins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 101
