The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
123 Questions View all
Can you use the series 1 1ST GEN screen to series 1 2ND GEN?
I have a couple of apple watches, STAINLESS STEEL 38MM (1ST GEN) Serial Number: FH7PR3xxxxxM with very poor battery life and SERIES 1 38MM (2ND GEN) Serial Number: FHLT11xxxxxC with a cracked screen.
Would I be able to use a screen from STAINLESS STEEL 38MM (1ST GEN) to replace broken one from SERIES 1 38MM (2ND GEN)?
Information from apple
5 Comments
There is no such thing as a Series 1 Gen 2
Lets see if you can clarify following this list:
- Original - Most parts are unique to it
- Series 1 - Parts (except logic board) are the same as Series 2
- Series 2
- Series 3 - Latest model some parts are the same as Series 2
by
Dan I don't know much about apple watches but I know what I am getting back from Apple Check Coverage :
Your Service and Support Coverage: WATCH SERIES 1 38MM (2ND GEN) Serial Number: FHLT11xxxxxC
by
Ha! Apple can't even call it by its proper name! Your first watch you have is either a Series 1 or a Series 2 depending on how you look at it ;-} Glass have full or half empty?
Your second watch is the original Apple Watch.
My Watch program on the iPhone tells me I have a Series 2 It should tell you if you have a Series 1, Series 2 or have the original. I would look at that.
by
The series 1 screen is the same screen as the 1st gen. Screen.
The series 2 is the same as the series 3 screen when it comes to connectors, but the series 2 screen has a sensor chip built into the screen and the series 3 screen doesn’t have this because it is built into the main board.
by
Would the lcd replacements between series 1 and 2 be interchangable bar that sensor in the LCD? Trying to fix one and figured the since they're both 38mm it may be worth a shot but I wanted to seek more information before I went ahead and got the replacement
by
Add a comment
Chosen Solution
Unfortunately you can't transfer the LCD to the other series one, seems to not be compatible.
Apple watch series 1 and 2 pretty much use the same batteries.
Source: Searched for the batteries and LCDs on eBay.
Score 2
1 Comment:
The problem here is Apple confused us by intro'ing a second version of the Original watch and calling it Series 1! The very first watch has unique parts which are not interchangeable with the newer Series 1 and 2.
I don't own either the original or Series 1 watches, but it appears Apple defines them as Series 1 (Gen 1) the first watch what most call the Original. Vs Series 1 (Gen 2) which is a Series 2 but with the slower CPU in the S1 board.
by
Add a comment
Here's the IFIXIT teardown & guides for the different watches:
You'll also find some YouTube teardown and repairs on the IFIXIT channel.
Update (03/30/2018)
@adamusik - Take a look at these two images and tell me if they use the same connector system
Original Apple watch (gen1)
Series 1 (gen2) & 2 as well as Series 3 which uses a different part
These parts are NOT interchangeable!!
The construction of the product doesn't conform to the model ID's
The original watch
  • 38mm: A1553
  • 42mm: A1554
Unique parts!
Series 1 & 2
  • 38mm: A1802 & A1757
  • 42mm: A1803 & A1757
Use the same parts!
Series 3 Use some of the same parts as the Series 1&2. The case, S1 board & display assembly are different!
The Apple Watch Edition watches are unique as well as Apple produced them using the guts of the original, those solid gold & ceramic watches Apple gave to the Who's Who celebrities before the roll out of the very first watch and sold for $10K to $20K. And later sold the White ceramic version which used the series 2 guts.
Score 2
4 Comments:
Dan first picture is Original Series and series 1 (models A1553, A1554, A1802 and A1803)
second picture is series 2 and 3 (models A1757, A1758 and series 3)
by
Well, I guess the Series 1 Watch I had put a new screen in was mis-marked ;-} As it needed the Series 2 screen. I had thought that too! As I had gotten the Original watch screen which didn't connect.
I guess you'll just need to find out on your own.
The only thing I can think of is Apple created two versions of the Series 1 watches, the first using the Original watches guts and the second wave using the Series 2 guts but with a slower CPU in the S1 board.
by
Can I swap a 38mm Apple Watch into a 42mm body and screen? Please help
by
@bigscrip - Nope! They are different
by
Add a comment
The first generation apple watch (aka. Series 0) is the exact same thing as the Apple Watch Series 1 (which came out with the Series 2 (Second Generation) but with a small processor upgrade compared to the original Apple Watch).
So an Apple Watch (1st Generation) screen will work on an Apple Watch Series 1.
Now Series 1 and Series 2 Screens are completely different and will not work with each other. And obviously a 38 mm screen won't work on a 42mm screen.
Score 2
1 Comment:
thats exactly what I thought, Thanks
by
Add a comment
I just found an article and looks like Series 0 and Series 1 displays and batteries are completely interchangeable.
Update (03/28/2018)
Dan check this (all information from ifixit)
Apple Watch Teardown
step 21
Apple Watch - Series 1
Andrew Goldberg's Article
"When we tore open the Series 2, we found a totally redesigned, streamlined, repair-friendly interior."
"To find out for sure, we warmed our iOpener and unsheathed our opening knife. With the display open, the verdict is … it’s a Series 0 in there."
"The construction in the new Series 1 exactly matches what we saw in our teardown of the original Apple Watch, right down to that annoying display cable bracket. That’s the exact same 0.78 Wh (205 mAh at 3.8 V) battery, right down to the Apple part number. Just to be sure, we checked compatibility with our original Apple Watch parts stock, and found that Series 0 and Series 1 displays and batteries are completely interchangeable."
Apple Watch Series 2 Teardown
Step 4
Apple Watch Series 3 Teardown
Step 5
Apple Watch Image
Guide
Difficulty:
Moderate
Apple Watch Series 2 Image
Guide
Difficulty:
Moderate
Apple Watch Series 3 Image
Guide
Difficulty:
Moderate
7 Comments:
Sadly Andrew is mistaken! I'll speak to him about making the needed corrections to his article.
The Original watch used a different connector system than the Series 1&2 as well as the newest Series 3. While the parts are similar the parts are not interchangeable! Square peg round hole problem ;-}
by
thanks for replying Dan but now I'm confused even more. So far there's 4 series of the watch.
Apple Watch (1st generation)
38mm case (Model: A1553)
42mm case (Model: A1554)
38mm case (Model: A1802)
42mm case (Model: A1803)
38mm case (Model: A1757)
42mm case (Model: A1758)
Apple Watch Edition:
38mm case (Model: A1816)
42mm case (Model: A1817)
Apple Watch Series 3 which does not matter in this case :D
Ogodeal Apple Watch 38mm New Screen Replacement Repair Kit Series 1 A1802 and (1st Generation) A1553
I have a look on Amazon and looks like Andrew is right.
According to the manufacturer:
This list is for Apple Watch Series 1 A1802 and Apple Watch (1st generation) 38mm (Model: A1553) if your Apple watch back side write 7000 series or series 1 38mm this is the right item.
by
Still wrong! See my update post above.
The part you've linked to by the image is a Original Apple watch display NOT a Series 1 or Series 2 display unit
by
series 1 and series 2 use completly different parts series 1 and series 0 use the same screen and battery. I repair them constanty.
by
The only thing I can think of is Apple created two versions of the Series 1 watches, the first using the Original watches guts and a second wave using the Series 2 guts but with a slower CPU in the S1 board.
I struggled with this problem about a year ago fixing someones Series 1 watch which in their case required a Series 2 display. So you've got me wondering... So far I've fixed about 5 Series 2's and only one Series 1. All the rest a good half dozen where the Original watch.
by
Show 2 more comments
Add a comment
Hello,
My Apple Watch SE 44mm 2nd Generation (GPS Edition) touch panel is broken. Can it be replaced with the SE 1st Generation 44mm?
Add a comment
Add your answer
Dawid will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 31
All Time: 9,436
