Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
Pro Tech Driver wobbly bits
Quick question about the screwdriver and the bits: Are the bits supposed to be wobbly and loose when attached to the driver? They stay in the coupling just fine but have a lot of side to side play. Is this normal/by design? If so, why was the driver designed this way?
Thanks in advance~
Score 1
Add a comment
1 Answer
Chosen Solution
There's a little play but not wobbly. Can you give a link to exactly which driver you got (they have changed over the years).
Score 3
9 Comments:
Thanks for the response Mayer! I believe this is the new 2016 version, it came with the recent Fix the World special.
https://drive.google.com/file/d/1B2wB3LL...
by
[linked product missing or disabled: IF145-360]
by
I just tested mine and there is little play in it but I would consider it wobbly. Take a look in the driver hole and see if the might be something in there (like a tiny screw) that would prevent the bit from fully seating.
by
Looks clear, just the barrel and the magnet. Are you able to roll the bits around in yours, making a light clicking sound? I realize that "wobbly is a pretty subject term so my apologies XD
by
I can turn it just a hair. There is certainly not enough play to make it click. iFixit does give you a lifetime warranty on it if you feel it is defective, they will be happy to replace it.
by
Show 4 more comments
Add a comment
Add your answer
Haoqian Wen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 390
