Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
No LED backlight after display swap on 15" MBP - HELP!
So I just tried to replace my high-res matte finish display with a glossy standard-res display. The install went fine but the machine wouldn’t boot. I disconnected the LVDS cable on the glossy display from the board and found that there were two contacts completely missing from the connector. So I contacted the vendor for a return and decided while I was waiting, to put my original matte display back in. When I did, I now have no backlight on the internal video at all. I can see that the display is producing video when I shine a flashlight through the Apple logo on the back of the display and I also do have output from the mini display port to an external monitor. All cables are properly seated and I even cleaned the LVDS connector on the old display and it’s accompanying socket on the board with isopropyl alcohol and compressed air. Was static safe the whole time. I did have to swap the plastic clutch cover for the hinges because the new display did not include one. Could I have pinched or damaged a cable related to the backlight? I assume the backlight is powered through the LVDS cable as that's the sole video related cable on the display that connects to the board. However, there are several ribbon cables below that clutch cover too. Any thoughts on what might have gone wrong would be highly appreciated. Not a newbie doing these types of repairs either.
Add a comment
1 Answer
the other ribbons are unrelated(front cam and mic)to your issue.being said that the main is the lvds i suspect the light fuse must have been blown in the process.probably the battery was not disconnected or so....now for that kind of repair you are the only one who knows you repair level,which model you have and find the schematic to help identify the 'light' fuse and so on.there is too much to do by yourself to ask someone else to guess and do it for you.it's tracing back steps,identify and rectify.
1 Comment:
Yes, thanks, I realize that the other cables are unrelated. After a bit of digging, I think you may be correct about the SMD fuse on the other side of the board. I’m gonna see what others have to say however before I pull the board to replace the SMD fuse. Of course, I’ll check continuity first. But I think the other display might have been the cause of the fuse blowing if it is in fact open. Thanks again for the suggestion.
by
Add a comment
Add your answer
Steven Wymor will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 58
