Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Why does my phone always die and restart at high percentages?
When I wake up in the morning, my phone will be at 100%, but the second I take it off the charger, it will start dropping fast until it gets in the lower 90’s. This takes less than 5 minutes. Then all of the sudden, it shuts off and restarts but goes to 10% exactly every time. It will stay at 10% for hours, but then it starts dropping again and dies. It takes about 2 hours for it to even turn on when I put it on the charger after it dies.
My friend dropped my phone a while back so I had to get a new screen replacement.. but I don’t know if this has to die anything with it
1 Comment
I dont know why but my phone was at 100% and as soon as I unplugged it it shut off and restarted and always goes to 10% i dont know why mabey because my battery capacity is 78 or its a miscalculation of my percentage
by
Add a comment
1 Answer
Chosen Solution
Probably not. You likely need a new battery
Parts
iPhone 6s Battery
Labor
iPhone 6s Battery Replacement
iPhone 6s Battery Image
Product
iPhone 6s Battery
$29.99
Score 3
4 Comments:
Second iMedics answer, unfortunetly it's a common thing to happen especially if you have updated to iOS 11 I've talked to a few customers whom are also having battery drain issues after updating. A battery replacement should help with lasting to a full day off of one charge
by
Hopefully he doesn't need to downgrade
by
I third @theimedic's answer, although you MAY be eligible for a free battery from Apple since it is an iPhone 6S.
If the iPhone has never been opened (it has in your case),
Or if it has been repaired by Apple,
OR if the screen was not replaced by Apple and your Apple employee is in a good mood that day and disregards the replaced screen (although technically a screen replacement should not void other warranties by law).
To check if you are eligible, go here and follow the instructions. If you are, you can try your luck at a nearby Apple Store or Apple Authorized Service Provider (AASP).
Otherwise like @theimedic said, just get a battery from iFixit and replace it yourself. If it a straightforward repair and iFixit batteries are GREAT (I use them myself for all my customer and they love them).
by
@rany screw Apple! Just get the iFixit battery! Rats...I'm out...of 6S...
by
Add a comment
Add your answer
Nick M will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 6,540
