Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Touch IC iPhone 6 PLus - C2414
Hi EveryBody.
I have a question plz only for general knowledge because I m learning about smd board repairing.
I have an iPhone 6 plus.
If I check the voltage on c2414 it will be 5 volt right?
My question is : the voltage wil be same with or without lcd connector attached? (obviously iPhone must be turn on :) )
I m asking because I have an iPhone 6 plus with no touch responding.
I check the voltage on c2414 and it was ZERO.
I reball u2402 and touch screen begin to function perfectly, but the voltage on c2414 is zero.
So I m confuse, I m not understanding which is the way for understand where is the fault, before recall or changing ic’s.
Thanks a lot for attention and forgive for bad English :)
4 Comments
c2414 is on the 5v rail. what does c2409 read
by
Thanks Daniel.. I did not check c2409... Cuold u plz explain what does rail meaning?? c2414 always have 5 volt or not? thanks
by
the best person for this question would be @refectio who is the guru of iPhones on here followed by a lot of really smart people like @theimedic and @djdannyrock . I am certain somebody is going to pick this up ;-)
by
can i see C2409 voltage track
by
Add a comment
1 Answer
Chosen Solution
Yes, you will have to have screen attached to see the PP5V7...Rail is referring to the particular circuit...The 5v you are looking for is on the PP5V7 rail, as seen in the picture I added...everything red is thePP5V7 rail, the other side of the capacitor is on ground. Here is a video that describes what you are asking as well...it starts at 3:30 into it but it is very helpful in Touch IC troubleshooting in the future.
Score 3
2 Comments:
thanks a lot Michael. :)
by
You are very welcome :) If the information I provided answered your question, please take a moment to mark it as the chosen solution, and if not...please let me know if you have any other questions and I would be happy to try and help. Best of luck!
by
Add a comment
Add your answer
Umer Muhammad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 448
