Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Loud fan, hot top left edge
I have an iMac 21.5" from mid 2011 that I don't quite know what to do with.
On startup, and initial boot, it's fine. After a while though, a loud fan-like noise occurs. Given enough time, the top-left of the iMac near the ventilation strip gets hot to the touch. It seems to be coming from close to the top of the iMac, so I thought it was the hard drive. I replaced it, thinking that might be the solution. (it wasn't but it can now run MacOS Sierra reasonably well, so I'm pleased with that)
I took a closer look, hoping to diagnose it further. I installed iStat on the iMac, and it showed that all internal temperatures were hovering between 97-148 degreed Fahrenheit. At this point, the fan(s) was (were) running quite loudly.
I poked around a bit on the interwebs, and came up with two possible solutions:
-Add a Digital Thermal Sensor
-Replace the CPU fan
Just looking for some feedback as to which course of action might be preferable. If more info is needed, let me know.
Thanks in advance.
Add a comment
1 Answer
Chosen Solution
Did you or anyone change the hard drive? If so, you diagnosed correctly and you need that thermal sensor from OWC.
Score 2
3 Comments:
It's a computer from the organisation I work at. I just replaced the hard drive today, but I see signs of it having been opened before. (this is my first month here) So my predecessor may have done some work as well.
by
@gryczewski - Alek - You should see this on the drives SATA cable: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade if you put in a non-Apple HD in.
by
So that part should be on there already?-- EDIT: Misread you, nevermind, thanks for the help :D
by
Add a comment
Add your answer
Alek Gryczewski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,201
