sreen blanks when lid moved
when i open the lid at some point the screen blanks. i removed the plastic edge besel. i move the wires near the hinge and i can make it come good. i think it is a broken or loose wire.
Jim since you already figured out your problem, now you only have to fix it. I would replace the cable since it is the most likely spot of failure. Not sure which Toshiba you have otherwise I'd try to find you a service manual or try to assist you otherwise. Good Luck
+ look for the Display Data Cable
Please could you tell me how you fixed the problem? My computer is exactly the same!!
Same computer? What happens? what have you tried?
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 824
