Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1273 Questions View all
sreen blanks when lid moved
when i open the lid at some point the screen blanks. i removed the plastic edge besel. i move the wires near the hinge and i can make it come good. i think it is a broken or loose wire.
Score -1
Add a comment
Chosen Solution
Jim since you already figured out your problem, now you only have to fix it. I would replace the cable since it is the most likely spot of failure. Not sure which Toshiba you have otherwise I'd try to find you a service manual or try to assist you otherwise. Good Luck
Score 2
1 Comment:
+ look for the Display Data Cable
by
Add a comment
Please could you tell me how you fixed the problem? My computer is exactly the same!!
1 Comment:
Same computer? What happens? what have you tried?
by
Add a comment
Add your answer
Jim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 823
