The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
Resistor value on 128GB SSD needed - please measure and share
Hi all,
I've been working on a water damaged 2015 Macbook air, following the amazing instructions from Louis Rossman, on YouTube. It's mostly working, but the SSD is dead.
Having looked at the SSD, I can tell a resistor appears to have blown. If you have this SSD, could you please measure it's value and share it? It would be a lifesaver.
Here is a picture of the resistor in question : https://photos.app.goo.gl/QEaVmaBhdgMc44...
The model is a MZ-JPV128R, 128GB out of a 2015 macbook air
8 Comments
@djdannyrock how do you figure that? How do you even know it is a resistor? You have the schematic? You measured it on your SSD....
by
Hi Daniel, how did you get the ohm value?
@oldturkey03 , wish I had the schematic, it would make this a lot easier. I just assume it's a resistor since it's black. In my experience, resistors are usually black, caps are usually red. Obviously I'm guessing, but without a diagram, I can't do much else.
by
Pierre Sarazin my comment was really directed toward @djdannyrock. I think somebody is just doing some guessing;-)
by
Show 3 more comments
Add a comment
1 Answer
Chosen Solution
11-12ohms measured on a dead MZ-JPV2560; component layout is identical in this area. Haven't got a 128GB SSD to hand but should be the same. Don't use too much heat on the SSD, PCB is thin and you'll boil the chip on the other side
Score 3
3 Comments:
Thanks so much!!!
by
FYI, I replaced it tonight with a resistor I scavenged from another MacBook ... the thing works! Thank you thank you thank you
by
Good to hear :)
by
Add a comment
Add your answer
Pierre Sarazin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 225
