Broken ethernet port (something snapped and now wiggles)
Hi All:
I've broken the ethernet port and now I cannot get online at home.
Is the RJ-11 the proper connection and if so, how hard is it to replace the plug?
Thanks in advance.
Glenn
Score -1
1 Comment
Please give us the last three letters of your serial number so we know EXACTLY which machine you have. Thanks
by
Add a comment
1 Answer
Most Helpful Answer
The ethernet port is soldered onto the logic board. You would need to have a component level repair done to fix it or install an airport card.
Score 3
4 Comments:
Apple iBook G4/1.33 14-Inch (Late 2004 - Op) Specs
Identifiers: iBook G4 - Late 2004 - M9627LL/A* - PowerBook6,5 - A1055
The Airport card addition may be the easiest way to go. If you do the teardown and take it into an old tech the charge should only be about $15-$20.
by
Hi Mayer:
The last three letters are "RCU". Hmmm...not sure if I want to mess with a logic board and a soldering iron.
Thanks for responding.
by
Thanks Mayer...I think that I'll just pick up a wireless router for now. The laptop does have an airport card, so I'll forgo the teardown. Maybe at a later date I'll do it.
by
You can use a USB wireless dongle instead of an internal airport card.
by
Add a comment
Add your answer
Glenn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,276
