Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
RAM slot went bad
Mac Book Pro Unibody 2012 A1286 macOS Sierra
Mac Book Pro 2012 Unibody macOS Sierra- screen starts flashing>horizontal banding then shuts off. Researched and found out one of the RAM slots is bad (not card issue). Removed RAM from defective slot. Now MB Pro is running fine, but with a single 8GB instead of two 8GB R AM (16GB total). I read that this is not uncommon for this model and is a motherboard issue. How can I fix this?
Score 1
2 Comments
guessing it was the bottom slot that went bad, its usually the pins thats soldered to the board
by
Yes it was the bottom slot! Apple recommended replacing motherboard would be only solution.
by
Add a comment
Chosen Solution
I've had success both tightening the bracket screws and loosening them. Also try a 4 GB stick in the slot, sometimes a slot will take a lessor stick.
Score 3
1 Comment:
Thank you. I will try both of these steps.
by
Add a comment
Check the Apple serial number sticker on top of the ram contacts. It’s a layered foil sticker and on mine the sticker seemed to have shifted or degraded so that the foil was shorting the edge contacts for the bottom ram slot.
I removed the sticker and placed a new layer of kapton tape in between it and the contacts and the problem was solved.
Score 1
Add a comment
Add your answer
Xmei Media will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,280
