The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
104 Questions View all
Where is the pixel wifi antenna?
my pixel fell onto ground and since then the wifi becomes very weak. wifi can be found but not connected unless i put the phone on the wifi router. maybe some problems are within the wifi antenna. i tear the pixel down but cannot find the wifi antenna. can anyone show me the position? really need help
Score 3
5 Comments
I am also facing same problem. Can you please tell me how did you fix your connectivity issue?
by
@tosepe  could you fix the problem? I have the exact same issue after i dropped it. It would be very helpful if you share what happened
by
How was the problem fixed? Was anyone able to solve it?
by
i have also the same issue with my pixel
by
My speeds on my pixle 3 XL is 15mb with data and Wi-Fi compare it to my Samsung note 4 and my note 4 is getting more than double of the speed my pixel 3 is supposed to get
by
Add a comment
Chosen Solution
Hi!
I think what you are looking for is in thisguide, at step 14. Those are the antennae.
Score 4
3 Comments:
Thanks for help! do u mean the black signal wire? is it itself the antennae? or the connecting wire between the wifi chip and antennae?
by
The both the black and white signal wires are antennae connected to the WiFi chip.
by
Hi there! I have this exact same problem too. Can you please tell me how you got this problem fixed? Thanks
by
Add a comment
Most Helpful Answer
if the above didn't work try to press little hard on the left right corner(next to power button where wifi chips sit on the motherboard) this is the most successful solution at least for me because I cannot get a replacement from Google because I am from Cyprus (my device is google pixel xl,
Hope the solution is helpfull for you or anyone who has this problem)
Score 13
13 Comments:
mine fell a floor from the balcony, broke the glass (not the screen) and the wifi.
thanks for the advice, works like a charm now. :D
by
thank you! i dropped my phone this morning and had the same issue. i was preparing to disassemble the phone and try to fix it but this worked like a charm!
by
You, sir, are a genius! I was looking at how to disassemble the phone because I had the same issue (the phone fell on the floor from 30cm, nothing got broken, but wifi stopped working). Pressing on the corner next to the power button FIXED IT!
by
Demetris, you saved me a lot of time and money!!! THANK YOU!!!! THANK YOU!!!! THANK YOU!!!!
by
thankyou v v much.. thank you.. this absolutely works.. thank youu à
by
Show 8 more comments
Add a comment
Thank you, my device has this problem, and I can use wifi simple.
Add a comment
Add your answer
taro.yu will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 102
All Time: 15,965
