Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
Add a comment
Chosen Solution
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
Score 1
Add a comment
Most Helpful Answer
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
Score 5
4 Comments:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
by
You are fine then, just use the original home button:)
by
Taylor, you accepted the wrong answer ;-)
by
@mayer at least she got an answer she is happy with ;-)
by
Add a comment
Add your answer
Taylor Fuller will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 68
