Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
What is causing screen issue after iPhone 5s battery replacement?
Hi,
I just replaced my iphone 5s battery and everything is working except for an issue with my screen when I press with moderate pressure. (I have linked a video to show what it looks like). What is it that causes this?
https://vimeo.com/229741314
Score 1
Add a comment
1 Answer
Chosen Solution
Those are pressure marks. That means something isn't sitting right underneath the screen and it applies pressure against the LCD when you press.
Go back through the battery replacement guide and check to make sure everything is in place. If you removed anything else to get at the battery (i.e. the Dock), then check that as well.
Score 2
5 Comments:
Ok thanks!- I will redo it now and see how it goes
by
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
by
yes According to my experience Those are pressure marks. the battery isn't sitting right.
by
Nice! thanks so much. It was how I installed the new adhesive tape, the tab was stuck to the front side of the battery and must have made contact with the LCD back plate.
by
My pleasure!
by
Add a comment
Add your answer
Sohan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 157
