Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Ifixit replacement battery doesn't fit in MacBook Pro
Recently I just bought a replacement battery for my MacBook Pro 15" Unibody Mid 2012 from ifixit and the thing is that it doesn't fit properly. And i don't wanna try to force it in because my previous battery which came with the laptop 5 years ago slides in perfectly.
The previous battery is A1382 10.95v/77.5Wh
The new battery is A1382 10.8v/77.5Wh
I don't know if the voltage is why the battery doesn't fit. I was expecting a 10.95 when i ordered it from this site.
2 Comments
This question was migrated from http://www.ifixit.com/Answers.
by
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
This model number is for the battery for 15" MacBook Pro models (Unibody, Late 2011/Mid-2012).
I think you may be trying to insert it incorrectly. The outside edge must be inserted first. Does it look identical to your previous battery? here's how to install it: MacBook Pro 15" Unibody Late 2011 Battery Replacement
Score 2
5 Comments:
yup it actually fit. thanks for the help. And so what about the voltage. my original battery had a 10.95v but this one is a 10.8v. Should i call fixit about it and have it replaced or does the voltage not make a difference.
by
@ekiflom small variations in voltage like that don't mean squat. They also average about 94% of the listed maximum charge on any new one.
by
Okay. I have read a few forums that after properly installing the battery there is something that you have to do with charging it and letting it drain.... something like that. Is there a guide that can show me on that or can i use the laptop right out of the gate?
by
Let it run all the way down then fully charge it.
by
Okay thank you for all the help.
by
Add a comment
Add your answer
Eyob Kiflom will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 870
