Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Questions View all
Which SSD should I buy, PCIe or mSATA, on iMac EMC 2638 (Late 2013)?
Hi!
I have iMac Intel 21.5" EMC 2638 (A1418; Late 2013). I want to add 2nd drive and didn't know which SSD should I buy.
I have already a 120 GB Samsung mSATA SSD (MZ-M5E120BW). Some time ago I've planned to use with this Apple blade SSD port Adapter/Converter for 2.5" SATA SSD installed into the case of a iMac (21.5 "or 27").
But a person had convinced me that my iMac has PCIe slot and I can't put mSATA in it. She said that I can buy M.2 SSD and put it in with this Adapter for mounting M.2 SSD PCIe in the Macbook, iMac, Mac mini 2013 - 2015 systems replacing Apples custom SSD.
I know that I can also buy original/OWC SDD, but it's not for me.
So my question is which SSD should I use?
1 Comment
Sorry the mSATA drive uses a different connection than the adapter you listed offers, it won't work at all.
by
Add a comment
Chosen Solution
Mind telling why the SSD that's built for a Mac by OWC, that works, is not for you? Instead you want to put in a module built for a PC that doesn't work reliably with a Mac. Now you're talking to someone that fits the adage "If you can't dazzle them with brilliance, baffle them with BS".
if the 21.5-Inch "Late 2012" or "Early 2013" iMac models were configured with an SSD or a "Fusion Drive" at the time of purchase, the SSD module is connected via a dedicated PCIe connector and another SSD can be installed in its place. Unfortunately, if the system only was configured with a hard drive, the needed connector is not present on the motherboard and there is not a way to add a PCIe-based "blade" SSD afterwards.
http://www.everymac.com/systems/apple/im...
Score 3
1 Comment:
Or...
Go with the Apple SSD like this one: Apple Original blade SSD - 128GB iMac 21.5"/27" Which is what I would do. But! you need to have the model that offers the blade SSD connection! Otherwise, you only have a single drive system.
by
Add a comment
iMac A2638 (Late 2013) uses PCIe Blade SSD and iMac A2544 (Early 2013) uses mSATA Blade SSD
1 Comment:
While you got the dialog correct you forgot the physical interface is unique to Apple. M.2 drives won't work.
by
Add a comment
To finish the story. You need an adapter for the proprietary M2 connector, which you can find on several places on the net, just google.
BUT :
If your iMac came without Fusion Drive then the M2 slot on the PCB is not enabled in Mac SMC (sort of Bios for PC’s ). So far I have not found a way to enable it and I do have searched a lot of fora.
My machine is a late 2013 21.5 that came with a regular 1TByte Hard disk. The M2 slot remains disabled. I tried using a connector that was said to be working for some in combination with a Crucial P1 1Tbyte nvme.
In the end I replaced the original (very slow) HD with a SATA Crucial 1Tbyte mx serries SSD and upgraded ram to 16Gbyte and it is flying ever since like better than new. Wishing I had not gone through all the trouble.
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 22
All Time: 2,377
