touch wont work after water damage
iphone 5s water damaged
changed lcd still no touch
changed touch connector on motherboard still no touc
changed touch ic still no touch
anyone any suggestion
Hi Adrian. Did you do a proper decontamination of the logic board (ultrasound etc.)? Was the water damage extensive or localized (if so, where)? Which Touch IC did you change; Cumulus, Sage or both? The more information you give us, the better the answer will be.
You should probe the the Touch IC voltage rails, both input and output and get to me with your findings.
i fixet it the problem was at the touch ic both ic was bad
so i bought a new one and now is working fine
Thanks for your reply anyway
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 43
