Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why is my phone dead but it is still warm
My iphone just goes blank (black). I cannot on or off, simply no response. When I plug it to the wall plug, no response too. The phone is hot. What should I do. Would appreciate your advice
Add a comment
1 Answer
Chosen Solution
Sounds like either the battery or board is shorted.
At this point first try holding home + power button for 10 seconds and try turning it on again.
If it still does not work then I would try another battery and if that still does not work then you might want to take it to someone that does micro soldering as it sounds like a board level issue.
Usually iPhones don't suddenly stop responding and get hot for no apparent reason so I would say the screen assembly and anything else connected to the board via ribbon cables aren't at fault other than maybe the battery.
Guide to replace battery:
How to replace the battery in your iPhone 5s
Where to buy an replacement battery:
iPhone 5s Battery
iPhone 5s Battery Image
Product
iPhone 5s Battery
$29.99
Score 2
Add a comment
Add your answer
ngui_pls will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,052
