Mac OS-X and Windows 7 issues
My keypad works great within OS-X, but when I boot up under Windows 7 it does not right click and the eject for the optical drive does not work
The older models only supported Windows 7 32bit make sure you have the correct version installed.
You'll likely need to check your version of BootCamp services. Apple updated it a few time for Windows 7. You don't want the newest as it only offers 64bit drivers.
Sadly, the age of your system does make it hard to maintain. I think you need to start saving your pennies for a newer system. I would recommend getting a i Series CPU based system (new or used). Then you can run the newer Mac OS's as well as newer versions of Windows if that is what you want.
Here's a good writeup on bootcamp: How to use Boot Camp with Lion
Here's an Apple T/N on the keyboard mapping: Use your Apple Keyboard in Windows with Boot Camp
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 834
5 Comments
What is the version of OX-X you are using?
by Dan
10.7, it is unsupported so i installed window 7, do i need to run the windows support set DVD again to make sure all the drivers have installed,, it said that they were installed
by R D Barnett
Can you give us your exact model here. Take a look at this list and see if you can tell us which one you have: EveryMac - MacBook Index
by Dan
MacBook "Core 2 Duo" 2.16GHz T7400 13" white, everything on the apple drive partition works great but these two things on the windows partition do not work, Model A 1181
by R D Barnett
Your system can support Mac OS-X Lion (10.7.5) thats the last supported on your system. You will likely want to max out the RAM to 4 GB.
by Dan
