Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Mac OS-X and Windows 7 issues
My keypad works great within OS-X, but when I boot up under Windows 7 it does not right click and the eject for the optical drive does not work
5 Comments
What is the version of OX-X you are using?
by
10.7, it is unsupported so i installed window 7, do i need to run the windows support set DVD again to make sure all the drivers have installed,, it said that they were installed
by
Can you give us your exact model here. Take a look at this list and see if you can tell us which one you have: EveryMac - MacBook Index
by
MacBook "Core 2 Duo" 2.16GHz T7400 13" white, everything on the apple drive partition works great but these two things on the windows partition do not work, Model A 1181
by
Your system can support Mac OS-X Lion (10.7.5) thats the last supported on your system. You will likely want to max out the RAM to 4 GB.
by
Add a comment
1 Answer
Chosen Solution
The older models only supported Windows 7 32bit make sure you have the correct version installed.
You'll likely need to check your version of BootCamp services. Apple updated it a few time for Windows 7. You don't want the newest as it only offers 64bit drivers.
Sadly, the age of your system does make it hard to maintain. I think you need to start saving your pennies for a newer system. I would recommend getting a i Series CPU based system (new or used). Then you can run the newer Mac OS's as well as newer versions of Windows if that is what you want.
Here's a good writeup on bootcamp: How to use Boot Camp with Lion
Here's an Apple T/N on the keyboard mapping: Use your Apple Keyboard in Windows with Boot Camp
Score 2
Add a comment
Add your answer
R D Barnett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 832
