Driver for opening MacBook Pro touch bar
Please can you tell me which drivers I need to open up MacBook Pro 15" Touch Bar Late 2016?
Are they available at Ifixit?
Best Regards,
Eric
Best Regards,
Eric
Looks like the P5, P3 & T5 driver are the main ones listed in the teardown:
From what I understand the P5 Pentalobe Screwdriver Retina MacBook Pro and Air is still needed for this newer model.
I do recommend you get one of the full kits as there are other tools you'll need. I would recommend this one: Pro Tech Tool kit as it has the non metal wedges and spudger tools which you'll need. It has the full selection of bits needed.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,303
3 Comments
Are you sure you need to open it?
Before you open your system this series does not have removable RAM or storage (SSD).
You may want to tell us why you need to open such a new system.
by Dan
Yes,.. Water damage....
by nedon
Sorry to hear that ;-{
If you can't get it working after you dry it out you still might be able to gain access to the SSD. Apple has a header on the logic board which we think is a direct port to the SSD. You may need to talk with Apple or authorized service center to see if they can connect your system to another to down load what it had on the SSD.
by Dan
