Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Small light bleed on bottom of screen after replacing home button?
So I replaced the battery and the home button and everything works fine, however there's a small spot at the bottom of the screen that's yellow across white and white across black in that spot on the lcd. Looks like backlight bleed and if i press on the screen it gets bigger with pressure. Could I have tightened one of the screws too much on the home button? Is it worth reopening to see?
Add a comment
1 Answer
Chosen Solution
Perhaps the adhesive used under battery too thick?
Battery is pushing against screen?
Could be something under screen e.g a loose screw, home button cable getting snagged.
Score 2
2 Comments:
but the screen has a protective metal plate between it. You mean between the plate and the glass, or under the plate where the home button is? It actually got a bit smaller since last night, you think it could get worse with time or damage the lcd?
by
Under the home button itself. It might just go away and even itself out over time which is fine.
by
Add a comment
Add your answer
Gerard Dalbon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,470
