Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
2 Comments
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
by
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
by
Add a comment
Chosen Solution
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Samsung Galaxy S6 Battery Replacement
Samsung Galaxy S6 Daughterboard Replacement
Samsung Galaxy S6 Battery Image
Guide
Difficulty:
Difficult
40 minutes - 1 hour
Samsung Galaxy S6 Daughterboard Image
Guide
Difficulty:
Difficult
45 minutes - 2 hours
Add a comment
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Add a comment
Add your answer
Amy ford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 156
