Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
no signal on my iPhone 5s, antenna problem
Hi there, I'm having problems with my iPhone 5s, basically it got wet and now it doesn't give me signal.
It's not a problem of reading
Sim, so it should be the antenna.
It doesn't say searching, it just says no signal, but when I'm near an antenna I have just one line of network, so very low.
Is it possible changing the antenna and hoping that it will work again?
Or it could be another problem?
If it is the antenna, is it easy chaining it?
As I said before it's not totally broken it works less then usual, when the signal is very strong it gives me one dot, inside building and away from antennas I have no signal.
Cheers
1 Comment
did you replace the charge port?
by
Add a comment
1 Answer
Chosen Solution
I would recommend trying the Lightning dock first. See if that's the culprit. Hopefully is, as you've doused it in water. I would also clean out the board with 90% or higher isopropyl alcohol and probably a toothbrush. This is a very low end clean, but better than nothing
iPhone 5s Lightning Connector Replacement
iPhone 5s Lightning Connector and Headphone Jack
Electronics Water Damage
iPhone 5s Lightning Connector and Headphone Jack Image
Product
$24.99
Score 1
Add a comment
Add your answer
antomar98 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,870
