Sony Xperia Z3 Compact released in Sep. 2014.
82 Questions View all
Screen stay black after replacement
Hi everyone!
I have this problem with my Z3 compact, I received a new replacement screen (broke the screen after me falling down and the phone being in my back pocket hit the floor first) and after fitting it, well it doen't light up! Everything else seems to work, the LED lights up when charging, power button works as it vibrates, camera button works as well (the phone vibrates when pressing it) so I think the phone does work.
Also I tried touching the screen, it does make the clicking sound, so the touchscreen is working.
The only problem is that the lcd stays black, no backlight, no images nothing at all! Tried to unplug the battery and plug it back in, still nothing. Volume+ and power did nothing as well.
Any advice or solution on this problem? Maybe the screen is just defective?
Score 1
Add a comment
Chosen Solution
Hi,
More than likely a faulty screen.
Try another one and see if that resolves your issue.
If it doesn't, then you may have to inspect the logic board for any damage. :-)
Score 1
1 Comment:
Sony's TFT LCD IPS Fuse exploded on Logic Board. Just solder it out. Use a Good Solder + Microscope.
Compact Z3: https://youtu.be/B3GHVfFs2hU?t=263
Logic BoardCHF 23.04 | 32GB Original Motherboard Für Sony Xperia Z3 MINI D5803 D5833 100% Entsperrt Mainboard Android OS Logic board Mit Chips ersetzenhttps://a.aliexpress.com/_BUGwJ5
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne Fhttps://a.aliexpress.com/_B0hkDt
Normal Big Z3: https://youtu.be/ZUm7n0tCZVM?t=45
5803 = EU + USA
5833 = Australia + Asia
https://www.quora.com/What-is-the-differ...
by
Add a comment
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne Frame
5803 = EU + USA
Add a comment
Add your answer
Anthony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 720
