I need to replace the disk drive
when i load the disk to install a program the drive is not reading its just spinning and then it spits the disk out
Hi, I am including a link to help you identify which MBP you have. Click on the unit that matches your and click on it. Then select replace optical drive replacement for a guide on replacing your drive. Go slow and be careful--you should be fine. I will also include a link for the part. Please confirm you have the correct part selected with ifixit before ordering.
where do I find this MBP
MBP stands for Mac Book Pro--if you click on the link it will take you to a page where you can identify which one you have. Then click on that link and select optical drive replacement and you should be good to go. Its the top link--MacBook_Pro.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 667
