Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why my jack play only one earphone after replacing the lightning port?
Hi
I have problem with my Iphone 5s. After lightning connector replacement (iPhone 5s Lightning Connector Replacement) I completly lose sound in one of earphone on any earphones that I connected and I don't know what is the reason for this. When I tried connect "old-damaged" module of lightning with old jack socked, the problem is same.
Do you know what is wrong with it? How can I fix it?
6 Comments
My guess is an issue in the audio circuit on logic board which requires diagnosing via schematics and microsoldering.
Otherwise physically damaged charging port connector.
by
Do the earphones work fine on another device?
by
Yes, it works great with anther devices
by
have to tried both headphone types, 1/8 inch and lightning connectors?
by
No, because I don't have headphone with lightning connectior. Anyway I would like to use standard jack as it is in Iphone 5s. I use my own headphones Sennheiser (not Apple product)
by
Show 1 more comment
Add a comment
Chosen Solution
That's what I'm thinking. You need to test a different pair of headphones, to rule that out. If the problem continues to persist, get your new Lightning dock exchanged. If that continues, then likely the Qualcomm. Which is not an easy repair, unless you have all the equipment and the experience to use it
iPhone 5s Lightning Connector and Headphone Jack
This is how to contact iFixit for an exchange
http://help.ifixit.com/article/136-email...
iPhone 5s Lightning Connector and Headphone Jack Image
Product
$24.99
Score 6
5 Comments:
Thank you very much for your response iMedic! As I said, I tried connect old iPhone 5s Lightning Connector with damaged charging port and working jack and problem doesn't disappear, but I think about new connector to test it for sure! Im going to buy new one and check it out. I will let you know what is the result.
by
Ok, today I ordered new one part and Im waiting for delivery. Keep your fingers crossed :) Estimated delivery time: friday
by
Why didn't you test another pair of headphones before purchasing this part?
by
I tried to connect another headphones and problem is same
by
Ok. Then we move onto testing a known good Lightning dock. One you know for certain is 100% working
by
Add a comment
Maybe there is simpler solution for my issue?
2 Comments:
did you try your phone with a different headphones?
by
Yeah, dude. We've both told you a couple times, to test new headphones to rule out the headphones being the problem
by
Add a comment
I don't understand it at all! After replacement part (twice!) is same and now I have not vibration and + volume button doesn't work :( (I didn't touch them!)
Add a comment
Add your answer
Bartłomiej Jakubczak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 175
