The case is dented where the MagSafe plugs in. How do I fix this?
Hi my Mac dropped on the floor causing the MagSafe charging port to be dented.
Anyone knows how to fix it or how much it will cost to repair? Thanks
This is a pic of the dent
9 Comments
This is repairable!
Can you give us your exact model so we can point you to the needed guide and parts. Go to this web site: EveryMac - Lookup Plug in your systems S/N which you can find either on the bottom cover or 'About This Mac' under the Apple menu bar Icon. Paste your systems URL here so we can see what you have.
by Dan
What year is the MacBook?
by Forza Vale
Honestly, its made of Aluminum, so if you can chisel away excess aluminum blocking the connection, you will be absolutely fine.
by Tech
Tech. That probably isnt a great idea as more damage could be caused in the process. Due to @danj 's answer, he probably know the perfect way to make it look decent again without destroying it.
by Cameron
@cam2363 is correct, using a chisel on a MacBook is ill advised, a mid case replacement is easy and there are plenty of guides to assist. We still need to know the year of the unit to proceed
by Forza Vale
Show 4 more comments
