Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
Why won't my computer charge from any charger?
My MacBook Pro (OptiBay'd but besides that mint condition) has periods where it will not charge. I have tried using other chargers and other outlets and it just does not charge at all. The MagSafe adapter light stays off too, and jiggling the cable around does not help. Then, eventually after seconds or many hours, it works again. This started off only happening occasionally but now has been happening for ~8 hour periods with only a few minutes break.
Other symptom is that I keep having random shutdowns where when my computer boots up again, my clock is reset back to 2000 and my Airport needs a password again. I have tried resetting the SMC/PRAM (dunno if that worked though).
Please help! What do I replace or do?
Score -1
Add a comment
1 Answer
Most Helpful Answer
Was it dropped? Water damaged? If no, and you are able to put it in factory defAults, just take it to apple store. They should deal with it...
Score 2
1 Comment:
+ agreed - take it in and have the warranty work done. Sounds like the magsafe port has gone bad. You probably reset the clock when you zapped the PRAM and have not signed on to the internet.
by
Add a comment
Add your answer
CStigler will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,405
