Question Closed
Not boot up. Just the led for a few seconds.
The macbook, does not boot. No start up chime.
When the power button is pressed, the light comes up for a 2 seconds, a little click near the hard drive then the lights off. The battery is ok, charging is ok. I've reseted the SMC.
1 Comment
There is no 17" A1260, please give us the last three letters of your serial number
by
Add a comment
Chosen Solution
It was a damaged LogicBoard
Score 1
3 Comments:
Really, according to whom? The most expensive thing it could be. You didn't give us much of a chance to help or help us help you. You might consider trying again.
by
According to my tests. My question was posted on December 29, 2010, and nobody gave me a little comment. 3 months is a long time if you or someone wanted to bring some help.
by
Easy folks, it has only been 1 1/2 month since you posted your question. You did not respond to the request for your serial number from the same day. Please remember that everyone on here answers questions voluntarily and tries to do their best. Good Luck
by
Add a comment
Sounds liek the hard drive bit the dust, try holding option when booting, and see if it give you a choice of drives to boot from
1 Comment:
I tested all components before: Hard Disk, Ram, airport, Fan, etc. that is why I say it is the logicboard. also is not the only case, since I saw two macbook air and a macbook with the same symptoms and all those had a bad logicboard.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 992
