2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
After going dead, MacBook will not turn on.
Hello everyone.
Like I said in the title my macbook pro will not turn on, no light, no vibration, nothing.
It went dead and sat for several days. I pluged it in and the magsafe light turned green instantly. I have tried reseting the SMC(cmd + leftshift + ctrl + powerbutton) no luck. Not really much else to try.
My personal best guess is that the battery needs to be replaced, but before i buy one i would like to hear yalls opinion.
-Thanks
8 Comments
SMC is reset by pressing on the left side these keys "shift, control, option" then power button command isn't a part of it. Other than that your not hearing anything coming from the inside of the computer? No noise from a fan? I ask this in trying to make sure its just not powering on and its not just the Display thats not giving video.
by
Nothing, no noise whatsoever. no sign of life
by
You have logic board damage that requires logic board repair - did you spill liquid on it? If so, cleaning the logic board and IO board with 99% isopropanol might resolve some of the issue(s).
by
press the power button, and as soon as you hear the startup chime, hold down Command-Option-P-R. Keep holding down those keys until you hear a second startup chime. Then let go and allow your Mac to continue starting normally.
by
Also did the battery die? If thats the case, try unplugging it and then trying to boot
by
Show 3 more comments
Add a comment
1 Answer
Chosen Solution
First try this: disconnect the battery and mag-safe. Press and hold the power button for five seconds. Reconnect the battery. Then the Mag-safe. Let us know it it tries to spontaneously restart.
OK, Looks like the battery may be kaput and won't take a charge. Here's how to change it out:
MacBook Pro 13" Retina Display Late 2012 Battery Replacement
I put methanol (a pure alcohol) in a syringe and shoot it under the battery to loosen the glue.
Score 3
1 Comment:
Thank you for your help!
by
Add a comment
Add your answer
Bryce Cole will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 12,365
