Clutch is slipping ... how do you repair or adjust?
I have a 1997 Suzuki Intruder 800 cc that has been sitting for a couple of years and when I started it up after changing oil and filter, clean spartplugs, etc. it has the clutch slipping when I ride it. This is a hydraulic system. How do you adjust or repair the clutch?
Score 3
Add a comment
Chosen Solution
@markpa28r , Mark A Murphy, You did use a good quality recommended grade motorcycle oil I hope if not change it right away. Bike clutches will sometimes slip after long storage because the plates go dry and can glaze over a bit. Give it a good run city/highway careful in 1st, try not to slip, go easy and see if doesn't come back or another trick I heard of was to over fill the oil to flood the clutch plates a few days then drain oil to correct level and try. Good luck.
Score 3
Add a comment
Most Helpful Answer
@markpa28r Hope you didnt use car motor oil in your bike . The shear stability of car oil is not good enough for the gearbox of a bike and its wet clutch system . it will work for a while but then as the velocity of the oil breaks down your clutch will suffer and die . It costs more but is defiantly worth the money to always use a good quality motorcycle oil . Next before replacing your clutch put the bike on the center kick and get the rear tire off the ground wieght the front end so the rear tire stays in the air then put the bike in gear and run it at an idle for a while then try giving it short bursts of power and watch for slippage as the clutches work in the new oil the clutch should improve. If this brings no joy and your clutch still slips heres a video to show the steps to changing out the clutch
https://www.youtube.com/watch?v=t-n86uKv...
is still uncertain there are hundreds of other youtube videos to watch on the subject . Hope this helps
Score 5
1 Comment:
@jimfixer , Good vid!
by
Add a comment
@markpa28r as clutch components wear, the fluid level in the reservoir will be lower as it automatically adjusts for wear. There is no routine adjustment necessary nor possible. Here is the part of the manual that deals with the clutch of your Intruder Intruder Clutch
Score 2
Add a comment
I had the same issue on my Intruder - after some 10-15 min ride clutch started gradually slip to a point shifting gear does not bring any effect, but bike stays as on idle...
Change of clutch brought no improvement...
Problem was - the pump on the handle bar: a very tiny (hardly noticeable) channel/hole for reverse of liquid was clogged not allowing the liquid to flow back which causes as if the clutch paddle is constantly retracted...
Hope this helps.
Score 2
Add a comment
Hello.
I have an Intruder 1400, year 2003 , and i am having problems with the clutch, it works pretty well for a while after the bike is warm enough while riding it for some time for some reason the clutch stops working properly, i have to stop and let it cool down otherwise i wont be able to ride.
Usually does this only when the bike is very warm, if i ride it for a few minutes it works fine,
I have changed the oil and had changed the DOT 4, any other suggestions…
Please help, thanks
Score 1
3 Comments:
Had the same on mine.
Changed the oil and clutch, but no improvement.
Problem was clogged valve on the handle (tiny one for returning the oil).
Hope this helps.
by
Is it simple to clear the clogged valve?
by
Hello guys! I got the same problem on mine vs 800. How do you clean the return valve in the master cylinder.?, Bleeding it backwards from the slave cylinder with a syringe?
by
Add a comment
I have a 2000 suzuki vl800 boulevard just put a new clutch in it. Now all it does is grind. In all the gears. Let off the clutch and it grins. What. May be the p problem with this?
Add a comment
PleaseHelp
My 04 suzuki intruder volusia vl 800cc will not engage the clutch when i pop dwn into 1st.. When i start the bike itll start but when i twist the throttle to give it gas it only pulls ever so little and propels the bike maby if im lucky 2 miles per hour thats in all gears i bought a. Clutch box. From socal dismantlers i took apart the bike got it the clutch box and took the plate off and noticed that the cork looking friction things around the discs were better shape than the$ 180.08 ones i just bought. So i throw it. Togeather and left how it was and the clutch cable is taughnt with a slight quarter sized gab inbetween nd its still giveing me same issues and its not staying. Running in first veary long it eventully dies out unless i have the choke out a lil.
Add a comment
Add your answer
Mark A Murphy will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 58
All Time: 16,245
