Repair guides and disassembly information for Android phones of all shapes, sizes, colors, and brands. Get everything you need to repair your phone yourself.
33631 Questions View all
Why does my car make a screeching sound when I turn?
Every time I turn right my car makes a screeching sound. Why
Add a comment
1 Answer
Chosen Solution
Marlette , If the screeching noise is coming from under the hood/front of car, it is probably the power steering belt slipping. As a first step check the power steering fluid level, if low top up. If fluid seams fine the belt may need adjustment(if able) or could be worn/glazed needing replacement or the tensioner/idler pulley could be defective. If all looks good there, the power steering pump may be faulty and require replacement. See links below for more info. Good luck.
https://www.youtube.com/watch?v=nEMiIKIM...
http://www.timeslive.co.za/motoring/2014...
https://www.youtube.com/watch?v=AEUe6uKx...
Score 3
Add a comment
Add your answer
Marlette will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
