Why does my car make a screeching sound when I turn?
Every time I turn right my car makes a screeching sound. Why
Marlette , If the screeching noise is coming from under the hood/front of car, it is probably the power steering belt slipping. As a first step check the power steering fluid level, if low top up. If fluid seams fine the belt may need adjustment(if able) or could be worn/glazed needing replacement or the tensioner/idler pulley could be defective. If all looks good there, the power steering pump may be faulty and require replacement. See links below for more info. Good luck.
https://www.youtube.com/watch?v=nEMiIKIM...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
