13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
X on battery after replacment
Hello,
This is my first time posting here so bare with me.
I'm working on a MacBook that came in. The number on the bottom is a1278, we ordered a battery for it but when it came in, it didn't work. It showed an x over the battery. I decided to return it and order one from Anker. Once I received it I installed it and again got that same x.
I noticed when installing the operating system I had no problem doing so with it unplugged. Even turning on the computer off charger works fine but once the OS comes up the laptop power down. It currently has Sierra. I did have it working at one point but it was brought back for the same issue.
Anything helps and greatly appreciated!
Happy repairing!
2 Comments
Is the X red or black?
by
The x is black
by
Add a comment
Chosen Solution
So, after tearing my hair out for 2 days. I finally found the issue. It was this battery sensor on the side, it was covered in corrosion. I unplugged it and replugged it after cleaning it with 91% alcohol.
Score 1
Add a comment
Most Helpful Answer
Black X? See this fine answer from @mactech : Black x in the battery charge symbol?
Score 2
1 Comment:
When I try the update
It says I already have this update
I also went to the system configuration folder and do not see the battery .bundle file
by
Add a comment
Add your answer
Jeffrey Ibarra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 52
