1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Removing the Wifi-antenna covering of a A1466 MacBook Air (13")
Because of a fall the cover of the wifi antenna of my Macbook Air 13” modell A1466 was damaged and obviously also caused a partial damage of the antenna itself. Only when being close to my wifi router wifi is working fine. It looks like some part of the antenna is not working anymore.
If possible, I want to avoid to dismount the whole lid and to install a new antenna. Is it possible without dismounting of the lid to just remove the cover of the wifi antenna to check whether the wifi antenne could be repaired by some soldering?
Thanks ahead of time for your support.
Add a comment
1 Answer
Most Helpful Answer
See step # 4 of this guide and check to see if your connectors are intact or need reseating: MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement
Score 3
1 Comment:
Thank you for your answer. The connectors at the wifi card are intact . It is the wifi antenna covered by the dark brown covering.
by
Add a comment
Add your answer
Ralph M will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 863
