Hewlett-Packard began manufacturing personal laptop computers in 1993.
maximum RAM upgrade?
hello sir
i have a HP laptop 2000 series 2128tu ...core i3-2328M CPU @2.20 GHZ
should i enhance its RAM upto 16 GB , i search on internet its showing upto 8 GB . but i want it to.. 16 GB .
is there any way or solution so can i upgrade it.. kindly assist..
Add a comment
1 Answer
Most Helpful Answer
@lightcloud , cloud user, As you may have already done, I did a search, which you can also try and no one recommended trying the 16 GB in the 2128tu which maximum is 8 GB. Forums stated would need different MB and probably core I7 while your at it. This probably would not be cost effective and may also require other parts. Good luck.
Score 1
2 Comments:
@lightcloud, the more important question is are you using Windows 32 or 64bit? You can check if you right-click "My Computer (or Computer or My PC" and select "Properties". This wills say on the screen Windows 7/8... 64-bit or nothing at all. If you are not running 64-bit, the PC won't see more than 3.72 GB no matter how much you install.
by
Add a comment
Add your answer
cloud user will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 726
