Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Screen makes click sound basically everywhere?
So i bought this brand new from a friend for a good price, box n all with still the cling thing on it when opening. When first got it i noticed bottom left was making a clicking sound so i unscrewed the bottom left screw, pushed hard on screen while screwing it back in and it fixed it for like a day or 2, now its back but the middle of scren kinda clicks to when i press it. None of the touch screen is affected but its gets kinda annoying, i usually fix it by pressing kinda hard on screen but today idk if i pressed too hard or what but screen like went black for half a sec while pushing middle to fix popping, nothing bad happened after and popping was gone. How can i fix the %#*@ clicking sound and if i have to go to apple store how much will it cost me. I rather do it myself. I am getting a case that pushes on edges of screen so that might end up fixing it anyways, a X-doria defense case with metal on sides and a plastic back i think. i want to know 1. how to manually fix the popping, 2 was the moment of black screen bad? 3. if i leave it will anything happen. 4 how much will it cost to fix if anything. and 5 will that case push on edges to stop it?
Add a comment
1 Answer
So almost guarantee your friend or someone replaced the screen in the past and it's not fitting correctly or making a tight seal with the housing. I would ask him if it's ever been repaired before
4 Comments:
Well he got it from his cousin who works at amazon, usualy it was like 400$ but I got it for 200$, he will say he doesn't know if I ask.
by
You could take it to a reputable repair store and have them pop it open or pop it open yourself. If its an aftermarket screen you'll usually have a small sticker or stamp on the lower left or right of the screen inside. Original Apple screens won't have this.
by
Ok will do that
by
So I took the screen off and there was no sticker or anything on the back metal part, I put it back on making sure I tightly click it from top down to home button. With no screws in bottom I saw the bottom right was a little more raised than the bottom left, I applied a large amount of pressure to the corner of screen with thumb screwing the screw in with other hand and same for left side and there is no more clicking, hope that lasts at least. My guess is one of the parts that has to click in on the sides inside the phone screen was a little loose and I just secured it better.
by
Add a comment
Add your answer
hyrqBot will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 24
All Time: 3,419
