Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
How do I recover a galaxy s6 from water damage?
I left my galaxy s6 in my bag with a water bottle and the charger. i opened it a few minutes later to see that the water bottle openned up and wet my phone and charger. i dried the charger then removed the phonecase and dried it. i soaked it in rice and didnt try to turn it on. i checked the charger on another phone and it worked( which gives some hope that phone isnt damaged) . but since the phone is galaxy s6 i couldnt remove the back so i couldnt really dry the battery. is soaking it in rice enough? I heard about some alcohol that helps with water damage but Im not sure how good it is. I really need this phone and cant afford a new one. thanks for the help
Score 1
7 Comments
My galaxy s6 tablet has water damage should I put it in water?
by
yes, submerge it in water.
by
Rebecca Woldanski - lol !
by
My galaxy s6 tablet has water damage should I put it in bag of uncooked rice?
by
Hi @ndnfjdnjnjdj ,
Please read the answer in the Chosen solution above, especially the link on "Don't put your device in rice, here's why...."
I suggest that you follow the recommendations in the Chosen Solution answer above.
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Hi,
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
Rice is good to eat but does nothing to fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit's guide on how to repair your phone. It is useful as it shows how to dis-assemble your phone so that it can be cleaned properly.
Samsung Galaxy S6
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Score 4
2 Comments:
My samsung s6 fall in water with bleach, soap and vinegar. I clean it with cotton and cotton cloths also suck around the phone, bottoms and holes. I think my mistake was try to turn it on. What should i make now??? Do you think he has chance to survive???
by
Hi @anape ,
Do what it says to do in the Chosen Solution above and hope that you can save it.
If you cannot do it yourself, take it to a reputable phone repair service as soon as you can.
by
Add a comment
Add your answer
bmba shush will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 27,385
