The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Replaced everything, Now what?
We have a Kenmore Elite washer, model 11047781701. We had some remodeling done and the washer sat for about 6 weeks. Hooked back up and got the dreaded F35 code. Replaced the analog pressure switch and got the same F35 code. Called a repair service, checked pressure switch hose and air dome then he replaced the steamer board and the main control board ($500). Washed four loads and got the F35 code. He claims the washer can't be fixed and we need to purchase a new one.
What am I missing here? Can something other than the analog pressure switch cause an F35 code? The washer also will throw a SUD and sometime an F20. Is there any information on voltage output of the switch that I can check? I have read numerous reports of people cleaning the dispenser and fixing the problem but that seems like a long shot.
Any ideas?
Add a comment
Chosen Solution
You know I really wouldn't use that repairman again. Ask him why he replaced the most expensive part. He did not leave the old part did he.
Show him a picture of a hole in the ground and your behind and see if he knows the difference.
Request a refund. If he doesn't give it to you, leave him a bad review on the internet.
This was my original answer to this problem and any competent repairman could find by just doing a web search:
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. If you are not completely confident in your technical ability to safely access and check these components, I recommend calling a service technician to diagnose and repair the washer.
Here is a very good answer on the SUD error which can involve the air pressure tube and/or sensor:
Why am I getting a SUD error message?
The F20 error code happens if the pressure switch has not tripped after 6 minutes.
Next time contact us before calling or repairing anything. The price is right, the site is manned by kind hearted volunteers who only want to help people.
Score 3
Add a comment
732grl , check out this repair info from an older post by @mayer , the pressure switch tube may be pinched/damaged or plugged. Good luck.
F35 error code appears during cycle
Score 1
Add a comment
Add your answer
732grl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,149
