Sony Xperia Z3 Compact released in Sep. 2014.
82 Questions View all
Broken digitizer or main board?
Hi.
I have replaced broken digitizer with original screen and frame from disassembled phone. After connecting new screen the digitizer seems to not working. There are unresponsive vertical and horizontal zones.
Does it mean that the new digitizer is broken or the mainboard?
Primary damage was located around back button.
Update (12/29/2016)
After checking second and third screen i know that it was digitizers fault.
Add a comment
1 Answer
Chosen Solution
Hi,
Try another screen before assuming that the connector on the board is bad.
Faulty parts can be received now and then, return the part and then try the new one, if it's the same issue, then inspect the board. :-)
Score 1
1 Comment:
Unfortunatelly i have no other screen near here and i want to avoid buying another one..
Did anyone diagnosed broken digitizer/screen connector after screen crack?
by
Add a comment
Add your answer
mraczka will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 270
