Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
2.9mm Standoff Broken in Hole Help
iPhone 5 Audio Control and Power Button Cable Replacement - Refer to step 35 of this guide
The 2.9mm standoff screw located by the camera actually broke off in the hole. Any suggestions on how I can re-mediate this, besides obviously ordering new screws (mainly to address the screw stuck in the hole)?
Add a comment
1 Answer
Chosen Solution
You could try to "grind" a slot in the standoff so that you can remove it with a straight edge screwdriver. I would remove everything out of the phone so that a small slip doesn't damage anything else. Otherwise, you could try some needle nose pliers to get it going. Normally, you don't need too much force to get these standoffs going.
Can you get a good picture so that I have a better idea of what you are facing?
Score 1
Add a comment
Add your answer
Aidan Brown will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 206
