Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Touchscreen stopped working after screen replacement
i just replaced screen on my iPhone 5s. This phone does not have SIM card, it was transferred to another phone. The screen is lit, charger is working, I can turn screen on and off. The problem is that my screen does not respond to any touch finger command including "slide to power off"
HELP!!!
Leon2472
Add a comment
Chosen Solution
You probably didn't connect the digitizer properly. This is the digitizer connection. Go back and insure it is properly connected. And don't mix up the screws to the bracket or you could cause severe damage.
Score 4
2 Comments:
This was excellent advise to properly reconnect digitize cable. The touch screen is now working.
The new problem: This is 5s phone. During the start up the screen lit normally but after the apple goes away, the screen goes dim and stays dim .
Any advice?
by
go into settings and turn the brightness up. If the brightness toggle is not working, its possible that the flex with the front camera and light sensor has a tear. Its also possible that the light sensor is not situated correctly.
by
Add a comment
Display and touch pmu problem, or battery high voltage 4v-4,2v, normally 3,8v. If battery high voltage, output display pmu high. Check u3 and Vbat = Vcc
1 Comment:
This was already answered more than a year ago. So you really dont need to post here also your answer is kind of confusing. where is the u3 located? Whats a pmu?
by
Add a comment
Add your answer
Sanevich will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 19
All Time: 360
